Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Aqwa – Field points definition › Reply To: Aqwa – Field points definition
November 12, 2024 at 12:25 pm
Hello Mike,
thank you for the consideration regarding the color scale matter.
Regarding exporting, it seems i'm lagging behind, because I'm using release 2024 R1 now. Then, it seems I need the update to follow your indication. To your knowledge, is there any alternative way in 2024 R1 to export the same data ?Â
Best regards,
GabrieleÂ
