Ansys Learning Forum Forums Discuss Simulation Fluids particle count on walls (Rocky) Reply To: particle count on walls (Rocky)
Lucas Bertollo Baggio
Hello Kiran,
Considering that you created an User Process (cube, cylinder, plane or polyhedron) around the wall, and from that you created the Particles Time Selection, you might use All for Domain Range, so what you will see in this Selection is the last particles positions before leaving the User Process region, for the whole simulation time. You will visualize but it won't help you to count the particles that stick to the wall.
To count the particles that stick to the wall, create another User Process, close enough to the wall that does not encompass the particles that bounce off it.
Then, go to the last output. If you hide particles and the other User Processes, the only thing you should see is the particles that stick to the wall.
From this new User Process, check the particles number (you might use the prepost scripting to check this Data).
Best regards,
Lucas
