The Ansys Innovation Space website recently experienced a database corruption issue. While service has been restored there appears to have been some data loss from November 13. We are still investigating and apologize for any issues our users may have as a result.
Ansys Learning Forum Forums Installation and Licensing Ansys Products What is the DIV meaning in *VOPER command when both par1 and par2 are arrays? Reply To: What is the DIV meaning in *VOPER command when both par1 and par2 are arrays?
mohan.urs
Hey,
I apologise for the confusion what i meant was DIV in *oper command is indeed for division.
The problem might be with your syntax that is why i provided those links.
if you check the 2nd link
Here this is the correct syntax for getting 1st derivative of an array D wrt time t in array A and save it in E. You just have to replace DER1 to DIV and point to your arrays.
Let me know how it goes.
Mohan Urs
