Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Improving Mesh Quality for Stability › Reply To: Improving Mesh Quality for Stability
November 12, 2024 at 11:13 am
- No, but remember inflation meshing is also a high aspect ratio if the solution changes along the cell.Â
- Yes, use inflation with extreme caution - see above.Â
- Possibly. That's one of the reasons we have dynamic adaption with pre-built criterion for VOF.Â
- No, but also avoid poly-hexcore in Fluent Meshing as the jump in cell size in the core mesh can be problematic if it coincides with the free surface.Â
- Yes, but I recommend doing it properly in the first place.Â
With multiphase instabilities may be real and a result of the flowfield.Â
