Mike Pettit
Which version of the software are you using? This looks like it is probably a bug, but it may be difficult for us to track down without your project files. Unfortunately we are not able to have files shared with us through the forum, but if you have a customer account number, please go to the Ansys Customer Portal and create a support request.
As a workaround, you should be able to use AqwaReader or AqwaGS to access the PLT file. AqwaReader is a command line utility which can create text output files, and is probably the easiest option; the user manual is here. AqwaGS is the old post-processor from the pre-Workbench days, and the user guide is here.
I hope this helps.
Mike
