Ansys Learning Forum Forums Installation and Licensing Ansys Products What is the DIV meaning in *VOPER command when both par1 and par2 are arrays? Reply To: What is the DIV meaning in *VOPER command when both par1 and par2 are arrays?
mohan.urs
Hey,
Can you check these links.
VM129 - explains the description of the problem which is very similar to yours.
VM129 Input Listing - gives the apdl input to solve and validate the problem. Check the code and change the missing parts from your code.
Reagrds,
Mohan Urs
