Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation › Reply To: Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
November 11, 2024 at 10:21 am
Hi Vijay,
Is there anything else you need from me to investigate the mass conservation issue in the methane pyrolysis shock tube simulation? I believe I've provided all the additional analysis you requested.
Also, do you have any recommendations for the chemistry model that would be best suited for this simulation? I'm finding it puzzling that, with identical numerical parameters, one model appears stable while another does not. Any insights on why this could be happening?
Thanks!
