Ansys Learning Forum Forums Discuss Simulation Photonics Parameter sweeps don’t work in Lumerical FDTD R2.3 Reply To: Parameter sweeps don’t work in Lumerical FDTD R2.3
Guilin Sun
"syntax error" error message mostly appears in script. Do you have any groups, or check the "model" and see if there is any script.
Please check this example https://optics.ansys.com/hc/en-us/articles/360034922873-Parameter-sweep-utility
I did a quick test with a new project file and new sweep object and it works fine:
