Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Image to file in Mechanical is bugged and does not show text › Reply To: Image to file in Mechanical is bugged and does not show text
November 7, 2024 at 3:58 pm
Update : Uninstalling and reinstaling ansys through the uninstall program in its file does not fix the problem.
List of other things that i tried :
-Changing the current display options through the image to file ribbon
-Changing the graphical options in the right top corner of mechanical
-Resetting these options
-Resetting project layout
-Resetting all cells of the project
-Deleted C:\Users\"User_name\appdata\Local\Ansys in an attempt to reset other settings
I will keep trying and i will update if a solution is found.
