Ansys Learning Forum Forums Discuss Simulation General Mechanical Image to file in Mechanical is bugged and does not show text Reply To: Image to file in Mechanical is bugged and does not show text
kostarak25
I tried the scripting approach to force my preferred image parameters. It does not work. I have the same problem as before when i used gui. The text remains invisible, as shown in the example picture at the original post, except only if i choose the default options within the code.
The interesting thing that I noticed is that it happens only for solution results. If i try to export the model as an image with any parameters it works just fine.
