Ansys Learning Forum Forums Installation and Licensing Ansys Products Problem using MATLAB with Lumerical 2024R2 Reply To: Problem using MATLAB with Lumerical 2024R2
Lito
Do take note that when shifting between Lumerical versions, you will have to make appropriate changes to the license configuration. Especially with the 2024 releases. Changing/running different version of Lumerical can cause the client licensing version error as indicated in the KB. >>How to fix Ansys client licensing software out of date error – Ansys Optics<<
Or a license error - if you switch between the older versions to the 2024 versions when you have a Lumerical Business or Academic (Standard) license. You will have to make sure that the domain in the License.ini file is set to the correct License Type for the Lumerical version you are running. See this KB for details. >>Lumerical license configuration from the command line – Ansys Optics<<Â
