Ansys Learning Forum Forums Discuss Simulation Electronics How to calculate the received power excited by non-port excitations? Reply To: How to calculate the received power excited by non-port excitations?
hariva3142
To calculate received power excited by non-port excitations, you’ll need to break down the electromagnetic fields and apply the right boundary conditions. It’s often tricky when you don’t have direct port access, but integrating over the surface of interest can help. If you need detailed guidance or help with these kinds of calculations, sometimes it’s easier to consult experts. Services like this one academicghostwriter.org can provide support with complex technical writing or research. Keep in mind that accuracy in defining excitation sources and analyzing the results is key when working with non-standard setups.
