Ansys Learning Forum Forums Installation and Licensing Ansys Products Mesh problem: Overall process does not start an got stuck Reply To: Mesh problem: Overall process does not start an got stuck
jordi.marce.nogue
Thank you for your prompt response! After trying several solutions, I discovered that the issue was likely due to having both ANSYS 2023 R2 and ANSYS 2024 R1 installed on my computer. Once I uninstalled the 2023 version, everything ran smoothly with the 2024 R1 version
