Ansys Learning Forum Forums Discuss Simulation Photonics Assistance Needed for Wavelength Adjustment in Optical Ring Modulator Simulation Reply To: Assistance Needed for Wavelength Adjustment in Optical Ring Modulator Simulation
abhishek_2311ee20
Dear Guilin Sun,
To achieve correct modulation, it is essential to select an accurate neff_vs_voltage_11.txt file corresponding to the target wavelength, in addition to adjusting the radius and length of the ring modulator. These parameters are critical to ensure efficient operation at 1550 nm, as they directly affect the phase shift and coupling characteristics necessary for optimal modulation performance.
If possible, providing an icp file specifically configured for 1550 nm would simplify this process. Such a file would contain the required values and preset parameters, ensuring a more reliable setup for precise simulation and performance at the specified wavelength.
