Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Honeycomb Shear modulus Calculation based on Analysis – ASTM 273 › Reply To: Honeycomb Shear modulus Calculation based on Analysis – ASTM 273
November 1, 2024 at 12:37 pm
Can Ozturk
When I calculated the Shear Modulus using the values you provided, I found it to be 45155.4 psi, which corresponds to 311 MPa. However, you indicated it as 617 MPa. Could there be a mistake in your calculation?
The values I used are: L = 7.417, b = 1.985, t = 0.626, S = 1.062e+6.
