Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Honeycomb Shear modulus Calculation based on Analysis – ASTM 273 › Reply To: Honeycomb Shear modulus Calculation based on Analysis – ASTM 273
November 1, 2024 at 5:53 am
Can Ozturk
Actually if you add it here I can open it at work. Also may I ask, I can't find the compression modulus and this was on workbench. I did it according to ASTM 365, and again I performed the test according to the sample dimensions in the hexcel tds, but the compression modulus of the Core was very different from the hexcel tds.
