Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Correct CFX Pre Setup to avoid isolated fluid regions › Reply To: Correct CFX Pre Setup to avoid isolated fluid regions
October 31, 2024 at 4:52 pm
Hi Mark,
I am using SpaceClaim and creating an Enclosure around the objects I want to simulate external flow around. I am then disabling those solid objects before going to the mesher as to just focus on the fluid enclosure. Do I need to create an enclosure and then use the combine tool? The solids I am using are CAD geometries that were originally .stl files that I used the AutoSkin tool on in SpaceClaim. They have no overlaps or unconnected faces.Â
