Ansys Learning Forum Forums Discuss Simulation General Mechanical Tensile Failure in Ansys but not in reality related to preload Reply To: Tensile Failure in Ansys but not in reality related to preload
gambra77
There is no error message, but the tension surpasses the tensile ultimate strength so i assume that it brakes in tat point. I used von misses stress.
The load is applied in the bolt with the bolt pretension function. Exactly in the bolt face that is not in contact (the contact that appears in the image)
I dont know if i did the model well.
thanks,
Aitor
