Ansys Learning Forum Forums Discuss Simulation Fluids Modelling Mixing Of Two Miscible Fluids In Agitated Vessel Reply To: Modelling Mixing Of Two Miscible Fluids In Agitated Vessel
You're adding a volume fraction, but depending on the size of the region (check the volume in Fluent's reports as registers aren't a precise volume) so you may need to do some thinking to get the correct mass or fraction.Â
