Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Modelling Mixing Of Two Miscible Fluids In Agitated Vessel › Reply To: Modelling Mixing Of Two Miscible Fluids In Agitated Vessel
October 31, 2024 at 2:17 pm
Leave wall bc's alone as you're just looking at the tracer flow. You may also want to look into running the flow steady state and then running just the tracer as transient. No reason to solve the whole lot transient if it's the same material properties: look at Solution>Control>Equations and do some reading.Â
