Ansys Learning Forum Forums Discuss Simulation General Mechanical ANSYS MECHANICAL – Setup Heat Flux as a function of a surface temperature in B.C Reply To: ANSYS MECHANICAL – Setup Heat Flux as a function of a surface temperature in B.C
dlooman
Your equation may be closely approximated by a temperature dependent film coefficient.  To account for the change in the formula over time you can run the analysis in a number of steps and respecify the temperature dependent convection coefficint at the end of each step.
