Ansys Learning Forum Forums Discuss Simulation Fluids CHT Simulation Using VOF Model (Steady-State) Reply To: CHT Simulation Using VOF Model (Steady-State)
If you decoupled the two walls there is no heat transfer between the two. You can add heat to a solid, or there's a wall heat generation rate (you must give the wall a thickness in the thermal bc part of the panel).Â
