Ansys Learning Forum Forums Discuss Simulation Fluids Post-combustion carbon capture using K2CO3 (Gas-Solid Multiphase Flow) Reply To: Post-combustion carbon capture using K2CO3 (Gas-Solid Multiphase Flow)
The Fluent solver has a reaction mechanism so will convert species based on the flow and chemistry that's set. If you're running a multiphase reaction scheme are the formation enthalpies appropriate for each phase? Ie have you accounted for phase change in the species enthalpy values?
