Ansys Learning Forum Forums Discuss Simulation Fluids Help: Setting of mooring lines Reply To: Help: Setting of mooring lines
Ingrid M
for catenaries, the weight should be at least 1.025 kg/m2 (your density devided by 1000). You can also increase the equivalent cross-sectional area so that the overall buoyancy is correct.
I hope this helps.
