Ansys Learning Forum Forums Discuss Simulation Fluids journal file Reply To: journal file
It's generally safer to run:
/file/rcd Cavity.cas
/solve/iterate 1000
/file/wcd Cavity_%i
etc
If you take shortcuts in the commands if Fluent isn't in the correct menu level the command will fail. If that's happened you may see an error in the transcript file. I'd also advise against overwriting files like that in case anything goes wrong. If it does you've lost both the results and potentially the input files.  Look up %i, %t and %f in the User's Guide: they're useful.
