Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Error Opening Rocky Projects › Reply To: Error Opening Rocky Projects
Hi w.p.goh,
Indeed, this issue will prevent you from opening your project on the current version.
In case you have access to Ansys Customer Portal, I recommend you try an older version. You can navigate on the Ansys customer portal and download an older version.Â
For example, you can try version 23R1 (Note: The oldest version on the customer portal is 22R2):
Another way to retrieve some of the content of the setup is by checking the "rocky_simulation.rocky20.log" file. You can find this file inside "simulation" folder in the ".rocky.files" directory.
In this file, you have some information regarding the particle, material and models.Â
Note you would need to scroll through the log file, besides that, it will contain only a few of information about the setup, like material stiffness, particle size, particle shape, and the models you had enabled.
Best regards
