Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Error parsing expression: “pwl($Tensile_modulus_with_temperature_462,Temp)”… › Reply To: Error parsing expression: “pwl($Tensile_modulus_with_temperature_462,Temp)”…
October 28, 2024 at 10:07 am
Ok iyt seems there is a bug when using 3d-layout component and 3d component which contain material from "Granta Materials" because when we use them, it add dataset on the project :
After importing theses components whith these materials, the datsets are imported into the global project and they cannot be deleted.
I think a solution is to clone the material without the dataset...
