Ansys Learning Forum Forums Discuss Simulation General Mechanical Honeycomb Shear modulus Calculation based on Analysis – ASTM 273 Reply To: Honeycomb Shear modulus Calculation based on Analysis – ASTM 273
peteroznewman
Honeycomb core is made by bonding sheets of foil and expanding them.
Another source of error is the presence of an adhesive material between the foil sheets which has a much lower modulus than aluminum.
Your model uses bonded contact to connect the foil sheets to make the 2t thickness instead of adhesive, so your model has a higher modulus than the physical product.
