Ansys Learning Forum Forums Discuss Simulation Preprocessing Multiple errors on simulation of force applied to a specimen. Reply To: Multiple errors on simulation of force applied to a specimen.
peteroznewman
You have a very large pressure load and very few substeps.  If you use 5000 Initial, Minimum and Maximum Substeps, you will be able to apply a small faction of the load.  The last image applies less than 1% of the load.
