Ansys Learning Forum Forums Discuss Simulation Fluids LWF model not working on a coupled wall interface Reply To: LWF model not working on a coupled wall interface
milad.mahjoo
Dear Mr. Rob.
Once again I really appreciate your kind attention. This is the same contour with node values off.
Left one is the correct case and the right one is the case that doesn't form correct wall on the target face (with non-conformal mesh). Number of streams are 100 and particle time step is 2e-5 (both of these values are selected with caution and get result independent)
