Ansys Learning Forum Forums Discuss Simulation Fluids Error Opening Rocky Projects Reply To: Error Opening Rocky Projects
Jackson Gomes
Hi w.p.goh,
It seems you are having a compatibility issue. Can you confirm the Rocky version you used to create the setup?
The log message indicates the error occurs because of a Fluid material entity.
There are some workarounds to try to open the project in the current version:
- If you created the setup in an old version, like 22R1, you can try to open and save the project on each version until the current 24R2.
For example, open and save on 22R2, then on 23R1, and repeat until 24R2. On each version, Rocky should warn you if you need to do some updates on your setup.
- If your project has results, you can try to remove the "simulation" folder inside the ".rocky.files"
Best regards
