Ansys Learning Forum Forums Discuss Simulation Fluids 3つの同じスペックのPCによるCFX分散型処理が実行できない Reply To: 3つの同じスペックのPCによるCFX分散型処理が実行できない
Ashish Khemka
Translated:
When performing calculations, parallel calculations are possible on two computers (desktop-2588ecr: calculation execution machine and desktoplem3u8d: node that provides only cores), but when I try to use a third computer additionally, I get the message "Credentials for rejected connecting to " is displayed, and parallel computation does not start.
The OS is all Windows 10 pro, and the MPI uses Intel MPI.
The password for each computer is setimpipassword.bat program is executed, and the name and password of all computers are registered.
In addition, except for the machine that executes the calculation, the ANSYS_DIR and ANSYS231_DIR are changed to the path of the machine that executes the calculation.
I don't know what the cause is, so if anyone knows, I would appreciate it if you could answer.
Best regards.
