Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Geometric stiffness matrix for solid elements › Reply To: Geometric stiffness matrix for solid elements
Thanks for your query.
In section 3.4, ‘Stress Stiffening’, you can find sub-section 3.4.3 ‘, Implementation’, which discusses how these matrices are calculated. Equation (3-60) onwards, will give more clarity in this regard.
Also, please mention the procedure (commands) used to determine APDL geometric stiffness.
Are you taking out element stiffness or global stiffness?
In addition, I want to check the procedure you are using to calculate the stiffness theoretically. What kind of elements/mesh are you using?  Is the mesh/element type comparable to the APDL mesh and elements being used?
Thanks.
