Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluent parametric sweep returns same values › Reply To: Fluent parametric sweep returns same values
October 24, 2024 at 10:21 am
The main fix is to change the check interval to about 5 so prevent convergence in the first iteration(s). Fluent has a built in parametric function now, but the process is also moving over to Optslang and attached tools to add in Digital Twin and similar functionality.Â
