Ansys Learning Forum Forums Discuss Simulation Fluids Help: Setting of mooring lines Reply To: Help: Setting of mooring lines
nguyenthithanhdiep1994
Dear Ingrid M,
Thank you so much for your response. I defined it following the AQWA manual. However, it has a problem with the weight/Unit length input. One of the mooring line sections has a lightweight cable with a Mass/Unit Length of 0.478 kg/m in section 2. And I can define this section's properties. Is there any way to create a lightweight cable?
