Ansys Learning Forum Forums Discuss Simulation LS Dyna LS DYNA/ ANSYS Installation Issue Reply To: LS DYNA/ ANSYS Installation Issue
alek.pach
Yes P:/ is a local drive, I took your advise and uninstalled and removed every trace (I could find) off the computer and reinstalled it under c:/ and I have the same issue.
So in intall.log I have the following which is normal:
There is no error directly in that file however it did indicate that it installed with an error and to check the install.err file and I got the following:
Which is an issue with 7zip? I use WinRAR, is there any chance they are interfering with eachother?
