Ansys Learning Forum Forums Installation and Licensing Ansys Products Mass-spring system does not move properly when the spring is non-linear Reply To: Mass-spring system does not move properly when the spring is non-linear
dlooman
Yes, the message seems to explain the issue.  Hard to imagine how making a spring non-linear turns a Transient Structural System into an Explicit (Rigid Dynamics) system!  When you change the spring to linear you make no other changes?  You don't use another project? Â
