Ansys Learning Forum Forums Discuss Simulation Fluids Visualizing velocity & pressure of fluid in Ensight when using two-way FSI Reply To: Visualizing velocity & pressure of fluid in Ensight when using two-way FSI
Rahul
Default it will just load the System Coupling results on interfaces. To see all the variables, you have to load the results of both participants in Ensight and it can be loaded as:
  1. Load results on Interfaces.
  2. Loading Mechanical results in Ensight: File > Open
3. Loading Fluent results in Ensight: File > Open
Also, refer to Postprocessing System Coupling’s Co-Simulation Results (ansys.com) for more information.
You can create a plane in Ensight using clip option. Please refer following tutorial Creating Parts with EnSight.
To create a scene as in the image, create a vector plot and pressure contour plot.
