Ansys Learning Forum › Forums › Discuss Simulation › Fluids › how to get time averaged contours in CFD Post? › Reply To: how to get time averaged contours in CFD Post?
October 21, 2024 at 10:18 am
Sampling is for as long as you save the data, so in your case it'll start at 8s. Note, the sampling is one extra data field per value, you're not saving any extra data files: just checking you were making a distinction between the two. Ie data files will be bigger but you don't generate extra data files.Â
