Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › CMSEL error. component is not defined – error › Reply To: CMSEL error. component is not defined – error
October 21, 2024 at 9:57 am
Erik Kostson
Hi
Where do u place this command snippet (show image)?
First nsll does not work in WB – it is an apdl command associated with APDL made geometry (you have not made it there – it is a WB geom.).
Also if you have it in H5 in the tree we do not need the /prep7 – if you use /prep7 which you have done, then you need to add /SOLU in the end.
Second try and rerun as I said and see if it works.
Erik
