Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Coupled field transient of brakedrum › Reply To: Coupled field transient of brakedrum
October 21, 2024 at 3:44 am
Hello Peter,
As you mentioned I've created a symmetry region as specified shown below,
Disc-
Pad-
Contacts are as follows,
Frictional-
Joints are shown below,
Revolute-
Translational-
Joint Force load is defined-
Joint rotational velocity is given-
Mesh is generated using 2nd order elements-
However, after running the simulation I'm getting error and solution isn't converging-
I would like to know whether the model is generated as per your suggestions and if not, would like to know changes needed to be made.
Rohan.
