Ansys Learning Forum › Forums › Discuss Simulation › Photonics › DGTD band structure calculation › Reply To: DGTD band structure calculation
I want to run bandstructure calculation of a 1-D array of plasmonic gold nanowires in DGTD.
I modified DGTD example “dgtd_plasmonic_dolmen” to include only one gold wire. I added “periodic” to the “boundary condition” and choose “simulation region” confined to “source_rectangle” (-0.06um to 0.06 um), I get
period=getperiodicity(“DGTD”);
?period;
0.06 um as xmin of “simulation region” is forced to zero.
I chose "x: set based on source angle" and changed source angle “theta” from 0 to 10 to 45 degrees. No difference in resonance frequencies (PEC or PMC symmetry) was observed (between different theta runs).
Is this the right approach?
