Ansys Learning Forum Forums Discuss Simulation Fluids Reversed flows after switching inlet boundary conditions Reply To: Reversed flows after switching inlet boundary conditions
Double check the pressure boundary - you may find Total and Static pressure are causing the problem.
You also need to check you're dealing with the energy (heat) in the mass source as that's not automatically removed from the domain.Â
