Ansys Learning Forum Forums Discuss Simulation Fluids nSmP battery connection arrangement in Fluent Reply To: nSmP battery connection arrangement in Fluent
Murari Iyengar
When setting up the Virtual Connections, you have two input formats available: 1. Tab surface-based format . 2. Active zone volume based format.
Both them are defined as mPnS. If you wish you establish an alternative format, then you would have to do it using a busbar. You can see 30.2. Using the MSMD-Based Battery Models (ansys.com) for more information.Â
