Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Contact issue in 2D analysis › Reply To: Contact issue in 2D analysis
October 17, 2024 at 8:26 am
I recommend using bonded contact for the regions that are initially in contact. To achieve this, you can split the surface and ensure the component set is shared.
For the regions where contact is expected to occur from the right side to the left side during the simulation runtime, you should apply frictional or frictionless contact, depending on your specific case.
