Ansys Learning Forum Forums Discuss Simulation General Mechanical Simulation stopped to work after switching the computer Reply To: Simulation stopped to work after switching the computer
mohan.urs
Hey,
The warning suggests that the BCs you have in the model might not be enough to constrain the body and there is rigid body motion in one or more direction.
If you think you have the right setup try switching the weak springs on in analysis settings and check if you can solve it after that.
Thanks
