hfarg001
Hi, Thank you for your reply.
But, so the microplane is a traiaxial stress placticity model. Tbh, I am not sure what do you mean by indicating it is for 1-D stress state. I did not use any command for identifying rienforcement inside the workbench I jused used the feature that create Rienf264 which I think it is same to the command.
In my sitution with the microplane model how I can remove it from the solver outpot. Does it make the displacement accumalte much slower through solution. Or it does not effect the results.
