Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Errors with multi-connected bodies using AQWA › Reply To: Errors with multi-connected bodies using AQWA
Hi! It sounds like you're encountering issues with the mooring line modeling. Since changing the joint type to a ball and socket didn't solve the problem, the error might be related to the linear elastic properties of the cables or the constraints applied to them. Check if the material properties and boundary conditions of the cables are set up correctly. can you guess How old is Hope Violet Garrett? Also, ensure that the model's degrees of freedom are properly constrained. If the issue persists, try simplifying the model or increasing the simulation's tolerance settings to see if that resolves the error.
