Ansys Learning Forum Forums Discuss Simulation Fluids Integrating Fluent Pressure Data into Mechanical for Riverbed Soil Stress Analys Reply To: Integrating Fluent Pressure Data into Mechanical for Riverbed Soil Stress Analys
luca.vene
Thank you for your response. However, I might not have explained myself clearly. What I need is to transfer the pore pressure within the soil to calculate the effective stress.
In ANSYS Fluent, I created a porous zone, and I would like to transfer the pore pressure from that zone to the corresponding volume in ANSYS Mechanical to calculate the effective stress.
Could you please clarify which command or feature I should use within the "Insert" menu of Static Structural to achieve this?
When I attempt to transfer the pressure data, I only obtain the pressure on the surface, so I believe I might be missing a step.
Thank you in advance for your help.
