Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Transient Thermal Analysis just shows a constant Temperature › Reply To: Transient Thermal Analysis just shows a constant Temperature
Hey,
Can you try checking one temperature at a time (max or min or Average) and check if its still not showing the variation (sometimes the variation of temperature is just in decimals).
You seemed to have scoped the heat flow to a very small face, which might get convected very fast and attain the equilibrium very soon hence you are not seeing the variation so try reducing the time step to a small value manually instead of program controlled and do confirm whether you are using the right BCs.
Try addidng a temperature probe and probe it to a single element near the small body and see if that is giving any better results.
If none of this worked, can you share your mesh density near the small body, contact setup you have between the bodies.
Thanks
